You can get this stuff from Halfords that works quite well, its a two stage thing. 1st stage gets off all the gunk; spray it on wait for it to work the hose it off. 2nd stage is like a coating that leaves a nice sheen on everything. Used it before and it works a treat, just make sure you cover up all electircs properly before you start!
I normally use the CO2 stuff from Halfords. Works like a dream! But beware that water does get into the electrics and after jetwashing the engine the ECU does store a load of fault codes due to this.
Best stuff I have found is the foaming tyre cleaner.... Get rid of the excess rubbish with Gunk and a paintbrush then just spray on the foam everywhere. You don't even need to wipe it off, it dries off in a couple of hours - best to leave overnight perhaps - and leaves a great shine that's not too bright and looks superb. It leaves everything like new and costs next to nothing.
Fair enough - but no higher than the manifold!
Otherwise it's Autoglym stuff for me and metal polish for all the... er... metal. Always make sure I start the job with at least two long fingernails.
If your really serious you take off the undertray and work from below - saves the knuckles
