HOWTO: SLK Evolution Pedal Mod - OFFICIAL MBCLUB MOD
Brian WH
East Midlands
JAGUAR XF 3.0D Premium Luxury
Don't forget this is the Official MB Club Mod
A must for all members
Part numbers as follows :-
W124,129,140,163,202,203,208,209,210,214 autos:
A 170 300 00 04 : gas pedal
A 170 290 01 82 : brake pedal
A 203 430 00 84: parking brake pedal
manuals:
A 170 290 02 82 : brake pedal
A 170 290 00 82 : clutch pedal
W211,C219,W220 etc ---- Priced @ October 2007
Gas pedal A 170 300 00 04 @ £9.25 + VAT
Brake A 170 290 01 82 @ £8.38 + VAT
Parking brake A 230 430 00 84 @ £4.66 + VAT
Brake and Footbrake rubbers fitted using small screwdriver to run round rubber to lever edges over pedals. Fit rubber at top first and then the bottom and sides can be levered on afterwards.
Pictures of process for accelerator pedal are as follows: -
Remove split pin, squeeze end with pliers and withdraw using screwdriver as lever under head of pin.
Remove old rubber by pulling off at top and sliding off carefully.
Remove new rubber from new pedal from packet.
Slide on new rubber to your pedal in reverse to removal.
Refit Split pin and job done.
Total time 15 minutes.
