rdk12
If this has already been spoken about on the forum could you send the thread?
Came across a topic on the web, how to increase your bhp with out remapping or chipping the ECU. This little devise is a piggyback box containing a resistor; it connects to the Intake Air Temperature sensor. Basically adds resistance to the wire, which fools the ECU into thinking that the air temperature is colder than it really is. The ECU then changes the fuel air ratio and timing, which increases output by 10 - 20bhp. It all sounds very good and takes allegedly 10 mins to fit and costs less than £5 for the resistor.
Firstly where is the IAT sensor? (model r129) SL 300 – 24 1993.. Is it mounted on the air-duct between the grille and the air filter box just before the paper filter? It has two wires No 1 and No 3 these wires then appear to go to another sensor under the air filter box (inlet manifold) where there is another possible sensor with wires repeated No1 No 2 No3 And if I was to buy said resistor which wire should I interrupt (add extra resistance too) Most importantly what do you technical guys out there think about the idea ??
![Cool :cool: :cool:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f60e.png)
