I have a 1993 CDi220. The alternator/battery warning light comes on intermittently, just for a second or two, then goes out. Recently this has been happening more and more (although it seems to happen more at speeds over 60). Had it checked by local independent who says everything checks out but agrees that, as its an intermittent fault, its hard to check. They said to bring it back when light permanently on then they can check! Car runs fine, no problems EXCEPT, if I'm driving at night, when the warning light comes on, headlights go out! This is only for a couple of seconds at most before warning light goes out and lights back on again - but, clearly, its not right.
I've read quite a few threads about this warning light but nothing quite like this problem (though might have missed it!).
Any thoughts? In particular, any suggestions as to what my local independent garage could do to diagnose (and cure) the problem without having to wait until its a permanent fault?
