Warranty will be fine, as a fully covert route will be taken that takes a little longer, this is not a cheap job...just what seems the best one I can find in the uk wanting not to effect the warranty.
Just renaming the file to the same as the original doesn't stop the ECU recording a software upload.
Just looking at the smoke output and the feel of the car says whether an ECU has been mapped.
The warranty is not going to be affected if something either not directly related to the power increase ( say windscreen wipers or wheel bearing) and quite cheap to fix fails. No-one will bother to look for a remap.
However, if something expensive like a gearbox or engine failure happens then the manufacturer might well want to investigate. If they want to look they will be able to find out if the map is different.
They will look at the update information that will be recorded, they might look at at a checksum value which will indicate changes; now you might say these can be 'spoofed' and you might be correct but at the end of the day they know exactly what the code and data should look and they can quite easily compare what it should look like with what it actually looks like.
Having said that I'm not against remaps and the like; it would just be better if organisations offering the service were more up front about the potential issues as well as the advantages.
Fair Comment....on the gearbox questions - The gearbox can take it no problem, the 7 speed box is also used in the ML420/ 450 CDI with not many changes, our upgrade is way under the torque threshold.
Will advise if the reference code route is the better way with demand in mind, cheers fellas!
Yep, No renaming a file and if you are returning for warranty work it can be changed back to original state if you ask.......Ta
iirc, the ECU still records the software upload.
Surely asking the manufacturer to support warranty claims when the car has been modified is wrong, isn't it?
In cases does the mapping company not provide a warranty or cover.
Don't forget that you are only putting extra strain on the engine when using it at full power, it's probably negligible in normal use. My s60 was mapped for more power and I never had any problems in 139k miles with it, not even a clutch (it was a manual)
NinjaMatt1 said:Fair Comment....on the gearbox questions - The gearbox can take it no problem, the 7 speed box is also used in the ML420/ 450 CDI with not many changes, our upgrade is way under the torque threshold.
The torque threshold for the box is 700nm. The DMS upgrade takes the 350cdi to 720. another poster indicated problems if you just go slightly over the limit. Note - the Brabus only takes it to 690 - for a reason no-doubt.
