blaza10 said:thinking of buying 2000 ml 270 its advertized with keyless entry how does that work?
marcos said:Did the old ML ever come with keyless go as an option?
Never caused me any problems (touches wood).esox said:I read somewhere that some insurers are refusing to cover cars with keyless entry..?
The credit card sized key has now been replaced with a normal MB key (strange I know) so the normal key has the radio transmitter in it.
As mentioned above, you only need to have the key in your pocket to open and start the car.
On the door handle's is a small button, when you leave the car press this button and the doors will lock. To open simply grab the handle and just as you go to pull the door handle the door will unlock.
The car can not be locked if you leave the key inside it, or in your wallet inside the car etc, so its fool proof.
The car will not start unless the key is somewhere in the car either.
I don't se the point now why pay an extra £880 for a key you allready have.
They are now £70 as I found out when it did not like a 60c wash,
And I've seen a lot of broken cards from people putting them in back pockets or whatever and then sitting on them.The convenience of Keyless go is nice to have, the reason it has been incorporated in the key was you are told to keep a normal key around in case the card key failed, with the all in one if the keyless part fails, then you can use it as normal
The key version is better than the card i think
