SilverSaloon
- Mar 16, 2004
- 1994 W124 E300D Estate, 1985 R107 280SL
hi
after selling my house we are currently renting a place until we find a new property to buy.
when we moved in we noticed 2 things that were not right. the heating is electric storage but are not wired in to the proper economy 7 wiring system, meaning if they are turned on at the heater appliance itself they are on 24 hours a day, whereas they should come on/off with a timer based on the enomomy 7 tariff....
cooker doesnt get hot enough to cook food most of the time, seems an intermittant fault which means sometimes if you compensate for it and turn the heat up higher you end up with burnt food, or if you dont its raw or takes 2 hours to cook oven chips etc!
anyway, 3 months after moving in and bringing these issues to the landlord (via letting agency) attention nothing has been done after several times chasing it up.
any advice on what to do next? is it unreasonable to tell them i will deduct X amount off the rent in a months time if its not fixed by then???? nothings getting done and its a real hassle, mainly the cooker. landlord says it worked as it worked with the previous occupant. cooker is part of the let as it came as furnished.
thanks for any advice
