LED light bulb replacements for W123/ W124/ W126
Screwdriver
Hi All,
I know that Kent over at Mercedessource is working on an interior LED light replacement kit for American customers. . .and was wondering if we had a compiled set of links for LED bulb (taillight, brake light etc.) replacement options UK buyers can purchase?
Appreciate any links with real life learnings (pictures preferred). Cheers!
Quick update : I just purchased a set of these for my brake lights. Assuming they work well, I will go ahead and replace the front and rear turn indicators as well as the reverse lights when the time comes.
OSRAM LEDriving P21W 3000K Warm White (Twin) | PowerBulbs
Any suggestions on an LED replacement for the red rear parking lights? I'm guessing we still don't have suitable LED H3/H4 replacements made by Philips/ Osram yet?
Thanks!
Did you spot the following in the 'features and benefits' section of your link:
  • Not ECE conform
  • Only for off-road use. Not approved for use on public roads when used in an exterior application. Illegal use leads to cancellation of vehicle operating licence and loss of insurance cover
Mercedessource ship to the UK.
The OSRAM led replacements worked great for the brake lights but won't work as turn indicators (too high of a resistance). If there is interest, happy to post pictures!
I was happy enough to get 2 additional pairs for my W124
Can I please request the tail light/ rear red parking light bulb model please? I've seen conflicting model numbers on several forums. This not for the brake light.
Can you not just pull the lights and look at the spec engraved on the metal base of the bulb? Most of my rear lights are P21W with the exception of the reversing bulb, I've replaced all bar the indicators with LED's.
Did these set off your bulb warning lamp? If you have one.
No. I carefully bought Canbus LED's. This is what I bought (from a different seller) for the P21W :
4x No Error Canbus CREE White LED Backup Reverse Light Bulb #L BA15S 1156 P21W | eBay and for the reversing lights something like this :
2 x 7.5W White Error Free T15 W16W LED Projector Reverse Light Bulbs Canbus | eBay
The only reason I did not change the indicators is that the lamps are too long in the rear light fitting of an S204.
For the W123, the reverse and brake lights will take the P21W bulbs. The OSRAM bulbs I've installed are far, far superior to the Ebay variety (but don't protect against any errors, none of which are triggered by the W123 brake or reverse bulbs).
The rear tail lights are a different, smaller bulb however. My bulbs have no numbers engraved - hence the question.
Thanks, so I just have to look for error free canbus I guess.
The back lights on the W126 are very moody looking and all, but a bit dim really. And no third brake light makes me slightly nervous.
Sorry for the hijack.
I bought canbus led bulbs for my C55 reverse lamps, and both caused an error message.
Sent from my LG-H815 using Tapatalk
£15 each compared to £2.30 each for the ones I bought - I know which I'm happier with!
1) That's not the price I paid. I used that link because its easy to view and read up on.
2) After applying the discount on that same website they work out to 12 quid each. That's around 2.50 more per bulb than what I paid.
Reason I first went over to using LEDs is that the standard small 10w tail bulbs were forever clouding over and were getting dangerously dim after a couple of months. Tried all different brands (inc. MB) & it made no difference. Never did get to the bottom of what was causing it. Same thing happened with my W201 & both S124s.
In the S124 the larger 1156/P21W bulbs go straight into the tail light's reflector hole without a problem. There's a diffuser/reflector in the lens, so the light gets spread out pretty well. The same bulb in the brake light position is much brighter and more directional as there's no diffuser.
In the W201 I had to file out the hole in the reflector slightly to accept the bigger bulb, but it was easy and worth doing. Easy to put it back to regular filament bulbs if necessary.
I'd stick with red LEDs for brake/tail- with white bulbs you're filtering out (& wasting) a lot of the light they're producing. You get a much richer red light too.
I got a pair of these for my reversing lights about 4 months ago- much brighter than the standard bulbs (not sure about the 80 W equivalent claim, but whatever). They're from China so no good if you're in a hurry. Took about 3 weeks to get to me.
2pcs CREE 80W White LED Tail Reverse Lights 1156 P21W BMW 3 Series E30 E36 E46 | eBay
I've been through a lot of the cheaper brands over the last 10 years and generally they don't last well. Lucky to get a year out of them. They always seem to fail due to a circuit problem rather than the actual LEDs- often banks of LEDs fail together. Crappy soldering that can't take the environment they're meant to be used in.
The Osram ones do appear to be much higher quality. I've got their white sidelights (nice warm white- not boy racer blue tinted) & orange side repeaters- they're all much brighter than the standard bulbs. Shame they don't seem to do a P21W in red...
I've emailed OSRAM and asked for it. They claim that their bulbs are doing quite well despite the premium pricing are determining market demand for additional variants. Wouldn't hurt if more of us emailed them as well.
