"Left Cornering Light" error
ScoobyDooLondon
Maidenhead, Berkshire
Mercedes S320 CDI 2008
Yesterday, a warning came on: "Left Cornering Light" with a graphic of a bulb.
Got home and took it out for a drive and the warning message was gone.
I checked under Messages and it was gone there too (I think I may have acknowledged it when I first saw it, so that may explain why its now disappeared)
Before I ring the mechanic, anyone know what this means? Does the bulb need changing or is something more involved?
thanks
Front left foglamp bulb? Does the appropriate fog light-up when you're in a tight slow turn?
Cornering light is sometimes just a small light in the headlamp that turns on respectively in the direction you're cornering, on my facelift lights the corner light is just a little H3 bulb I think
I haven't checked - I'll need to get someone to drive the car and whilst I observe.
Hopefully its just a bulb change and not the light unit itself.
You should be able to see the light, in mine it's angled
Should be a h7 headlamp bulb, you can see it through the headlamp as above, you can also see the failed element.
Got an appointment on Sat for a free summer health check - will see if they can do free fitting on the bulb.
