Lightshow
Adam230K
German oil burner
Right basically when i lock my car, or unluck it, the green AND red lights both blink for longer than needed. Anyone know why?
something about battery running low on your key fob do you have your manual i'm sure it says something in there.
Change the battery in the key fob then you have to 'resync' the system, if that fails i believe you have to disconnect the car battery for a few mins then when you reconnect all should be ok.
The exact process should be in the manual though
I would go with the batteries need changing in the key fob as well.
Yes it means low battery in the fob, it's covered in the handbook. You can confirm by trying your other fob (assuming that hasn't got a low battery too!).
thanks guys
