Location of W202 Cruise Control module?
Stratman
Sunbury
W203 C200 CDI '04Estate
Please forgive the posting in multiple forums.
Can anybody tell me for certain the location of the cruise control module in a '97 W202?
It isn't up behaind the brake pedal and I am fairly confident that it isn't one of the two modules under the bonnet in the module box which also contains the diagnostic socket and a small fuse panel.
You know who knows the answer to this question?
Your local Mercedes stealership.
Shudder!!!!
Stratman said:
Shudder!!!!
No I'm serious! If no-one knows on this forum, and you've tried others, why not pop in to your local stealership maybe even just the parts dept and buy some screenwash or other cheap item like a bulb kit and then slip the question out, they're usually very helpful! :)
EDIT: I just realised that my posting vaguely resembles the opening credits for the A-Team :)
Sounds like a fair option. I'll give it a go and post the results here.
Thanks.
The cruise control is part of the engine ecu, located under the cover on the l/h side of the bulk head.
My mistake, the c180 has a seperate module, same location though.
