Lost tv tuner!
ianjay
Bishop Auckland, County Durham
Mercedes S320cdi
Hi All.
Can anyone let me know where the TV tuner is on a (March) 2002 S320 W220.
Acording to the local dealer it is in the boot by the C\D Changer.
but there is no sign of it.
And yes the TV does work, but I want to plug in a dvb-t tuner as the system is still only analogue.
Many thanks in advance.
Ian J.
Did you remove the side trim / carpet? It is in the boot. Try a search may be a post with the exact location.
Hi All.
Ian J.
Should be there if it was installed in the OEM location, on the inner part (underneath the trunk carpet) of the left hand side.
WIS Pic attached:
Yes you need to take out a few plastic screws / retaining clips of the panel surrounding your DVD / SAT unit and it will be behind the panel.
as above hidden behind the boot trim - not blatently on show (no point!)
