cerbera84
Hi
I'm about to remove the rocker cover on my M102 W124 coupe, in order to get it powder coated along with the air box lid. Is this fairly straightforward? I've located the 4 stud bolts are these the only thing that are required to remove it (I would have tried removing it but it was too hot still). There appears to be an oil breather pipe that connects to the rocker cover and the air box does this just pull off? I've also ordered a replacement rocker cover gasket in preperation from the dealer.
Cheers
Chris
Cheers
Chris
