ddentrec
I am rebuilding my W123 280TE; the engine has had a top-end rebuild, including a new duplex cam chain. The engine is still out of the car.
New cam chain is the original MB £££ part, 140 links, exactly the same length as the old one (I double checked before I started!).
So, imaging my confusion when I find that I now cannot put the camchain tensioner back! It seems that the chain is effectively too short = chain is already tight before the tensioner has even been replaced = tensioner being pushed too far away from chain = cannot bolt tensioner to cyl. head.
Now, I'm not stupid and have rebuilt many engines before. The timing sprockets are all aligned OK, tensioer has been reset, timing is spot on, all chain guides & guide rails in place, no kinks in the chain, engine can be manually turned over with no tightness.
Is this a one off or is there something about the M110 straight six I am missing?? Any advice appreciated.
