Haughian24
I currently have a CLK 55 W209 N/A M113,
The car has just been finished and is a pretty good replica of the CLK 63 Black series with regards to the exterior apart from the carbon fiber parts...
So now that it looks decent enough, its just lacking power..
I have remapped the car and also put quad exhaust system on.. i'm guessing just shy of 400bph...
Now...
Do i spend more money trying to get more power out of this engine?
Or do i buy a M113K engine either buy a E55 and take it out and tune that engine?
Pros and Cons
Keeping the original engine (M113 N/A) i can put a supercharger on the car with cam shafts and headers but that will only see me to 500-550 bhp and cost about 7-10K...
I'm limited to the supercharger i can put on the engine due to the engine having a high compression ratio, so i would have to run low boost.
so i think right there is point why i might need the M113k engine,,,,
i could change the pistons in the N/A engine so that they are dished and i could lower the compression ratio, but then finding a supercharger that will fit that car and have variant pressure would be difficult.
I have already spoken with Kleemann and Weistec and they don't offer a supercharger that will be able to do that and say the M113K supercharger wont fit on the N/A engine due to dimesnsion and also the M113K engine has a bypass valve and their superchargers use this bla bla bla....
also while all the modifications will be going on i wont have a car to use....
now on to buying a E55....
i could buy a E55 with the M113K engine, remove the engine and tune the engine as and when..
I could buy a uprated supercharger, cams and headers, pulleys the lot also change the pistons to forged pistons and refurbish the engine with a full recondition. hopefully getting into the high 6's
But doing that will cost much more...
The reason for buying a whole E55 with be to have all the ecu, gearbox ,dif all the spare parts that i might need....
I don't want you guys to read this and think ive already made my mind up, i just want some advice on what else i could do. what other modifications i can do and so on...
Now...
Pros and Cons
