Just wondering if any members, particularly in the Essex area, have the Star diagnostic equipment? Reason I ask is because I would like to enable Xenon headlamp option before I fit a HID kit.
You'll get errors regarding certain bulbs being out (even though with the kit, they are on and working)
On STAR telling the car Xenons=On (or Present) will get rid of one, this basically tells the car xenons are present in a car which has the option, yours might not have. The kit I used had included manufacturer wiring so after this was done the car simply needed this option 'ticked' on STAR
The rest of the dash errors can also be cleared with STAR
As far as I know it's also illegal to have Xenons without headlamp wash as it's an MOT failure! As people have already said you will get errors due to height sensors not fitted as Xenons can't be adjusted on the dash like normal lights..
As far as I know it's also illegal to have Xenons without headlamp wash as it's an MOT failure! As people have already said you will get errors due to height sensors not fitted as Xenons can't be adjusted on the dash like normal lights.. Sent from my SM-G920F using Tapatalk
Illegal only if fitted from factory and not working properly
For example, it has levelling and washers, past owner fitted halogens and took xenons out and the previous two items don't work
If an owner fits HID's or retrofits xenons from another model, there's no legal requirement to fit washers and levelling etc. The only requirement would be that they are at the correct level (can be adjusted manually) and that they are fitted within the correct projector housings
