Hi Guys,
Just bought a front end damaged W164 for the wife, to replace her BMW X3, the car came off a lot worse than than the lamp post............so bad in fact that it has smashed the sump and lower engine casing.......not to worried about this though as the engine still turns with the crankshaft pulley.
The main issue i am trying to trace is that none of the lights work (brake and headlights), the ignition lights do not come on, although the mileometer will show mileage, engine obviously won't turn at this stage....and you can't operate the auto gear lever to get the car in neutral.
The smart key still operates the doors and the central locking.
Main battery been removed, checked and charged, aux battery holding 12 volts, checked all visible fuses in engine trunk and side panel.
Am sure this is all related to the crash, is there maybe a fusible link, reset etc hidden somewhere?????, does the car need reset etc because of the presafe ??
Any ideas guys ???
Bob
Any ideas guys ???
Bob
