I'm not that good when it comes to cars and mechanics.
I've had my 2011 - 313 Sprinter for a while now and I have had the error 'P0252 Injection Pump Fuel Metering Control “A” Range/Performance (Cam/Rotor/Injector)' for sometime. The van lacks power, sometimes as soon as I start it, it runs for few seconds before going off, I've had the problem for a while, the injectors have been changed, the EGR has been replaced and the fuel pump I've replaced today, I'm not sure what else can be the reason? I've spoken to people and have been told it might be the Fuel pressure regulator so I'm thinking of removing it myself giving it a clean or something.
It was fine a week ago, now the problem is back and it can be a pain in traffic as I have to keep revving the engine to prevent it from switching off and the max RPM 3000 when it is running. Its an on and off problem, its fine for a bit then it occurs again. Im clueless on what can be done, so please if you've ever experienced the problem with the error code P0252 on your sprinter, please share your knowledge.
Cheers
W
Cheers
W
