mercboiuk
Good evening everyone.
As some of you may know from a recent thread, I'm considering a Twin Turbo project for my E320 Coupe.
As mentioned in that thread, I wish to do everything properly and to me that means sorting out braking and suspension first.
It also means, if it makes a difference, I'd like to upgrade other parts of the running gear.
I have previously asked about C36 AMG items fitting my coupe, receiving a resounding "No" "not worth it" response.
And so, this brings me to my following similar questions, but this time referring to items from an E36 AMG estate with 230,000 kms on the clock.
I've seen driveshafts, propshaft, 3.06 differential with ASR, and what the seller refers to as "AMG wheel arches" hinting they are factory modified for larger wheels.
Also, the same seller has an E36 rear brake setup along with an SL500 front brake set up for sale.
In the same vein as my older C36 item thread, is it worth purchasing, restoring if necessary, and installing all of the above?
The front brakes I'm pretty much going to go for.
The rear brakes are a possible if it's worth it.
But are the prop, drive shaft and diff upgrades worth it and more importantly will they fit my Coupe?
Advice is always welcome!
Many thanks in advance,
Darren
Darren
