phill993
Now here's a funny story .... Car has been laid up for some weeks (completely flat battery) then moved across the country on a transporter.
Now with a freshly charged battery the sat nav thinks it is still where it started off, some 200miles away! I can even plan a route to where it is located now!
Everything else on the comand works fine (Audio/TV/Phone). The display is currently showing 8 satellites are being received, which varies depending on weather conditions, etc - so I assume the antenna and reciever elements of the system are OK.
Any ideas whats causing this?
Is this some kind of weird memory lock-up?
Is there a way of re-booting the sat nav (APS) processor?
Why didn't it reset itself after being powered down completely (flat battery)?
All suggestions gratefully recieved!
