MarkGolf997
- Feb 18, 2018
- Location
- London
- Porsche 964 + 997, Eunos Roadster Turbo, VR6, Focus RS
Cheer Grober, I've already ordered a new OVP but I'll investigate the old one, always like to know what the problem was, I'm going to look into the vacuum system, I've found out where I need to look so fingers crossed.
Thanks Bill, it is rather long, can't say I even noticed but it will disappear soon, I plan on fitting a DAB headunit so bye bye analogue and no more long aerial.
Thanks Doodle, indicators are working fine, I'm going to set the wipers to position 1 and wiggle the N10, if no good I'll take a look at the relay you mention and check that out with some contact cleaner to hand. I have come across some relays already which needed a tap.
I dont suppose the mirrors have their own relay other than the module under the passenger footwell? It's as if something is stuck on for the passenger mirror, as grober mention, weak door loom at the hinge, a bridge cable could cause what I'm seeing or if relay driven, a stuck relay..
