Nav module
Loofah
Mercedes C220 cdi amg
I'm still getting to grips with my new merc so learning slowly...
I have the sat nav prep all present but could someone tell me more about it and options available please?
Assuming it has the cradle in the glovebox, you need a Becker Map Pilot. Available from Mercedes for around £500. Available on Amazon from Becker for a nice saving ...
Richard
Does the Becker map pilot allow use of the hands free button on the steering wheel?
By handsfree, do you mean the phone pickup and hangup buttons ?
If so, that is a function of the car stereo rather than the add on map-pilot.
(I have assumed your car is a very recent W204 C Class from your answers, as you seem to have acknowledged having a cradle for the map-pilot in the glovebox)
Richard
This might help, I think it has the car configuration in it - http://www.mbclub.co.uk/forums/new-member-introductions/190825-new-merc-new-user.html
The button just above the handsfree which looks like a head with sound coming out (terrible description i know!)
I've just read about a Garmin map pilot - is that an option for this car or am I restricted to the Becker?
a) Your car is a W204 with Audio-20 and the Becker pre-wire options.
b) Only Becker i'm afraid. The Garmin stuff is in the W205, and consists of an upgraded head unit (which may be standard in UK) and a SD card with map on it
c) That button is the voice recognition button, and is not supported with Audio-20/Becker
There is one other option, have the Audio-20 replaced with COMAND NTG4.5. That has a bigger screen and much better navigation system in-built, which voice recognition. But its a few times more expensive than plugging in a Becker map-pilot.
Becker map pilot manual: https://www.beckermappilot.com/manuals/Manual_MAP_PILOT_EN.pdf
Hope that helps !
R
Thanks for that - bit annoying about the voice recognition button but not to worry.
Very much doubt I'll replace the audio 20, several hundred quid is already enough!
Cheers
I have a 2014 registered C220 and Becker/Audio 20 combination, and can confirm the speech recognition function does indeed work. Press the button (R/H side of wheel) and speak an address. The Becker will search - sometime successfully, sometimes not...
Loofah,
I have a Becker module that I have just removed from my '62 W204.
If your looking for a module and your interested pm me.
Thanks ! I didn't know that.. R
Loofah,
Do you still have the Becker module and how much do you want for it??
Terry
Terrymac1973 said:
Do you still have the Becker module and how much do you want for it?? Terry
I was going to list it on flea bay for £250, but would take £220 on it.
Comes with original box, cables, etc.
Unmarked condition and fully working.
Interested, have you got some pictures??
And the original Becker cable.
