Navigation APS 2007 - Sound issue
janel
I wonder if anyone can help, I recently purchased a CLK on a 07 plate which has come with the above navigation system.
This worked fine to begin with, but has know turned into the "Nav Whisperer" and I can barely hear the traffic guidance. I hadnt fiddled with anything, the volume just dramically reduced. I have tried going into Settings, Nav Vol, but this only seems to adjust whether the radio is turned down for the Nav Whisperers announcements.
I am probably mising something really obvious..unfortunatly my handbook that came with the car was for the S20 Audio system, but not the one with the inbuild Navigation system, so I havent got anythign to refer to.
So would really appreciate any guidance as this is really frustrating..
many thanks in advance
Jane
You are right, you missed something obvious. :) Navigation audio level needs to be adjusted when the lady talks to you. Press the repeat previous announcement if necessary to make her talk and then tune the volume up.
Someone must have accidentally adjusted the volume during navi announcements.
Thank you
Thank you so much - that has of course fixed it! So embarressed it was that easy and the amount of time I have spent on it!
thanks again
Jane :bannana:
