Neatest way to get 12v power to top of dashboard on W203?
Richatom
CLC350
Hello,
I would like to fit a Coyote S to the top of the dashboard on my W203. Can anybody give any tips on neatest way to install 12v power supply? I don't want cables trailing down to the fag lighter, so ideally would like to lead cable from dashboard/windscreen intersection.
Theres a fusebox at the end of the dashboard under the cover. Can't remember which end, but thats a good permanent power source. Switched power needs to come from the cigarette lighter. You can put a trailing cigarette lighter socket out of sight behind the dashboard and plug the device into that
R
