mdelfunt
- Nov 15, 2016
- Location
- Georgia, USA
- 08 E320 Bluetek 200k miles, 06 e320 CDI, 290k miles.
Hey team - new here. I may be in the wrong place but I didn't see a specific diesel section. I'm struggling with what I thought was a simple job of changing the injector seals on my 06 CDI. I started with the first one and its still an ongoing process.
After pulling the first injector and changing the seal and putting back together, she will crank over but will not start. Turned the key off and on a few times but nothing. I loosened the fuel line going to #1 injector and there is fuel coming out. Thinking that the injectors are not openning, I've started looking at possible fuses that I might have blown but can't find which fuses might be the root cause. This seems so dumb that changing the injector has caused this. I'm going to see if there are any codes but since there has been no-start since I finished, I don't know if anything will be there. I read that it may take a long time to crank after changing the injector due to air. I've about run my battery down and no luck.
AND while bleeding some fuel out if the fuel line to that injector, some fuel went down around the injector and it's BUBBLING, Crap. The new seal didn't seal. When I did the job, I cleaned the surface of the head and injector. A little bit ago, I tried to see if the stretch bolt would tighten a little more to see if the injector was loose and sure enough, the bolt striped the fragile aluminum threads. I've ordered a TIME-Sert kit to redo the threads. What a pain in the butt. While waiting on that, I'm pulling the next leaking injector. God only knows what else I'm going to run into. Still looking for wisdom on why it wouldn't' start and any other advise. Thanks team!
Mark
Mark
