partsspecialist
we have had a couple in our showroom, and being the resident tech geek i get time to play with stuff and make sure i know how it works!!
Yes but dont update the S/w on your original iphone as if you do, you will get the same problem.
Hi guys i can confirm that the 3G iphone works fine with the iphone cradle, phonebook works etc, as does the 2.5G iphone with latest software.
The lead on the cradle is for ipod funcionality on NEW cars fitted with a new option, universal media interface. it is a socket inside the armrest.
Does the cradle allow text message access with Comand?
Does the iPhone cradle charge the iPhone 3G? I know some older connections don't charge the new iPhone 3G. And are you still able to control the iPhone's iPod capabilities through the steering wheel?
The cradle charges the iPhone 3g and control of the iPod functions are available through the steering wheel controls.
A problem I reported earlier regarding the audio from the iPhone not being muted on some occasions when making a call, appeared to be due to the fact that the iPhone needed to be reset as it was not functioning correctly.
Kind regards,
Steve
Interestingly, the iPhone cradle uses a bluetooth connection to pass the iPhone's contacts list to the telephone system. This must be because the contact data is not available through the data port on the iPhone.
Steve
Thanks Richard - I had read that the cradle was too wide for the drawer but understood it could be mounted on the side of the stereo console. If this is the case do you have a rough idea of the likely cost involved?
By the way, let say I wanted one in my W203, which has an iPod kit and pre-wire - how would the cables be connected since my iPod kit is in the glovebox and the phone kit in the arm rest?
Is it just me being slow again?
(probably) :bannana:
The cable runs from the ipod kit along under the centre console to the phone cradle. It basically connectes the iphone phone cradle to the ipod kit.
Have you actually confirmed that this is true by trying to connect the cable as you describe?
Yes. We have installed a few of these now. They work well.
The awkward bit is getting the cable up into the centre armrest neatly.
Does anyone know if this is the case, or should the equipment I have had installed display the audio features on the COMAND screen?
