New pump for active seats needed
goodeone
Surrey
Mercedes E320 CDI W211
Just wondering if anyone has a pump for the active seats on a w211 (52 plate) going spare, my motor has burnt out and all the carbon vanes in the pump have broken up. Maybe someone might know of any other pumps that could be used and where I might buy something that will do the job, I can't afford or justify the price Merc dealers want for what is a total luxury. The pump lives in the boot on the passanger side behind the trim, encased in foam rubber.
I have the same problem, but my pump is fine.its the housing that has become warped with extra heat generated from the pump and melted!
If you do get a replacement pump and if your housing is in a good state, I would buy the housing off you :)
I think the housing is ok, you would heve to swap the internals though as mine is destroyed. If you want it you can have it as it's no use to me, If you come and collect maybe I could try your pump in my car to see if everything else works as it should.
Ah when I say the housing, I mean the air "block" that the pump is connected to, inside the black plastic case. Whereabouts do you live?
I understand now, If I find a new black box or fit a different pump inside I will let you know here.
Thank you but still out of my price range for this luxury, I think I might need every penny just getting the dam car running correctly.
