sunman
- Aug 15, 2004
yes, code the cluster first and see if the option is there. Enable it if so. then I would get the harness and control module with switch. Before installing all teh antennas, I would plug the module in with switch to the respective connectors. Probably CANBUS, power and ground. Press the switch and see if the display changes. If so, you're set for the install.
