R129mine
replace my wives picasso with a CLK cab, not sure which engine size yet, as long as it is not faster than my SL
finish my coupe, get something with a V8 in it and I suppose I really ought to buy a micro town car thingy for convenience etc (yes, that last one is a bridge too far)
If a project I am working on comes to completion I will buy an E60 w124 (because I'm worth it [flick hair, look to camera and smile])
or if i could convince the mrs, a 500E.......
Can you work out where you're going wrong..
My car is 10 this year so planning some serious pampering
ARB links and bushes
Engine mounts - front (would appreciate some guidance on if i should replace any other mounts i.e., rear
New Front Springs (old ones were put back on after the spring perches were relpeced last year !!!- i'm sure one was broken at the bottom
New front shocks (not sure which ones i need - Bilsten B4? any comments welcome) - again - should i replace the rear also?
New Brake disks and pads - all 4 corners
Plastic moulded tray under engine - that pap who did my exhaust last year damaged it when he dropped the cat!! - cosmetic yes but it bugs me knowing its cracked
Steering rack gaiter - the pap damaged the heat shield too
Internal trim piece to drivers front door - the long finishing strip that is fixed to the car body and goes round the entire internal door void - not the rubber door seal - fag burn!!
Internal finished cover to the drivers side A pillar - fag burn!!
Underseal to car - full boona treatment
ATF and diff fluids
vallet , wash and wax
The above mechanical items are being replaced not because they are shot, but that i think they should be replaced as the car is getting on now
i have tended to replace only when needed -over last 3/4 years (appart from waranty work) only 1 set front disks/pads, yearly oil and filter/services (indi), tyres
Popping down to the deallers now for some prices
Any thoughts on where i could make savings on parts would be appreciated - note itend to use OEM or better quality parts only
Was thinking it would be a good time to register and subscripe to the MB parts website - can someone post the link please
will post-up the quotes when available
I feel better now afterwriting this post that i am somewhat more committed to doing the above work - some of the above items are oustanding from last year!!!
You can't really go wrong with ECP or GSF ---Both have depots in Scotland ECP Edinburgh/Glasgow GSF Glasgow if you are anywhere near. Get OEM quality/ German sourced stuff you should be fine. The official online site is http://www.mercedes-benz-parts.co.uk/ I notice they are doing an extra 10% discount on brake discs/pads in January if thats of interest? coupon code:- BRAKES09
Buy a good used C63 for less than half the new price - Persuading my girlfriend that its exactly the same as the oil burner we have now...
Should be fun when she fills it up..
