no ignition lights at all w124 e300 d
mayfair
durham
mercedes w124 estate
hello
w124 1994 e300d 120,000 miles
turned igniton and have no lights on binnacle at all
clock works ,elec windows work but no ignition whatsoever.
checked all fuses in box,all ok ,is there another fuse anywhere else that could be causing this?
key turns as it should
any suggestions (battery works windows so that is good just not ignition lights or power to starter)
all help greatfuly recieved
al Durham
hell optimus prime
many thanks for reply much apreciated,
fortunately I managed to trace fault to the ignition switch not turning at the rear of the unit
Unfortunately i am having the usual nightmare of getting the barrel out of the metal shroud ,half a dozen angled
bits of coat hanger later still not sliding out
Will be trying again tomorrow ,i am sure to get there soon
once again many thanks
al
was meant to say hello not hell :)
even keyboards on the blink now:(
al
will do - managed to short the wiring at rear to prove the fault ,the engine turns etc - so definitely
a faulty barrel or the female part of the plug at the rear
somebody has been at it in the past and give up !as the pins dont slide in easy ,barrel seems to be off centre
there was a new lock centre in the rear boot compartment and wood screws holding the under dash cover up as well
as behind the facia trim.
will get sorted - trying to resist -disc cutting metal shroud off thats cheating ,but may well happen
, as in the past :wallbash:
cheers al
