- Jul 1, 2010
- W209
Just always wondered the reasoning behind each say build cost, fuel consumption, space in the bay and power etc etc ????
Cheers
Brett
Cheers
Brett
Cheers
Brett
I guess a flat six is just a V6 with an angle of 180 deg between the banks rather than 60 or 90 .
V6 was the choice for front wheel drive applications as it was a much more compact than a in-line 6 and often shorter than an in-line 4 cylinder, a V6 has higher torsionally stiffness in the crankshaft and camshaft(s)than a straight 6 but because of the "odd" number of cylinders per bank do suffer from dynamic imbalance that often requires balance shafts to improve smoothness.
An in-line six engine is in perfect primary and secondary mechanical balance without the use of any additional balance shafts.
given your username shouldn't you have asked about flat sixes too?
There is an additional problem in this green day and age for I6s in that they are usually (slightly) less thermally efficient than V6s, meaning more CO2/less MPG.
The real reason is length of the engine, an I6 won't fit in many engine bays.
