NTG 2.5 vito viano antenna
zenman63
Warwickshire
2016 L450 Range Rover 4.4 AB, 2015 GTs 2017 Range rover evoque
Just a quick note on the late vito antenna for the NTG2.5 if retro fitting.
Its new from Mercedes and has 2 inputs for the antenna, both Fakra.
You need another wire from the twin white angled plug on the back of the nav and run this to the amp up under the upper control unit, a new wire is avalable from Germany.
The late amp is self powered, or powered from the nav antenna wire, there is no plug for the power any more.
On Star it shows both antennas now as antenna 1 and antenna 2
It works very well no more scratchy radio 2, and the station list is full.
The amp is about £40 from merc.
