Hi guys - I am in need of your sage advice! apologies for the long intro to my problems...
I recently bought an x reg w210 320 cdi estate. I got it cheap off a friend as the suspension needed fixing which is done. I have since had the following problems:
1) occasionally it goes into limp mode (max 2000 rpm). This happens a few times a week and tends to happen when going up steep hills. I have changed the MAF sensor which has made the performance better, but unfortunately it still limps occasionally. As soon as I turn the car off and restart - all is well again. Apparently no codes are showing and there are no malfunctions.
2) The car must have had leaking injectors for some time before I got it as there was the usual thick layer of black stuff all across the top of the rocker cover. I took it to my local independent (INAUTOS, Sussex) and they cleaned up the injectors and claimed they were fixed. A month later, and not only are at least two injectors blowing, but there is now liquid diesel sloshing about on the top of the rocker cover around the injectors.
My questions to you learned folk are therfore:
1) any ideas as to what may be causing the limp mode
2) is it usual for injectors to go again so quickly after apparently being repaired - should I have faith in the same garage again?
Any advice would be most welcome
p.s. almost forgot - ABS, BAS EPS lights occasionally come on symultaneously - I changed the break light switch but it still happens. Systems work inc break light even when warning lights are on. Not too worried about this.
