OM605 Chip Swap Help
PaddyEnglish86
Mercedes W202 C250TD
Can someone run me through the chip swap process please. I've got the chips and sockets already. I now want to familiarise myself with the process before I pull the ECU out. Thanks
I know a couple of people who've done this. Will see if I can help...
FB group message sent...
Thank you. I just need to know which one goes where. There's two chips that look exactly the same. One has one dot, the other has two dots.
Sent from my STF-L09 using Tapatalk
My friend who has done this, said:
"He needs to talk to sean treacy on the std group. They need soldering, not a novice job really".
I actually bought them off Sean but I think he's away at the moment. I know how to solder and everything. I just need to know which way round they go. Thanks mate
If its a standard eeprom then its easy enough to get datasheet for the pinouts and orientation m8
Thanks for your help mate. He's put one dot on one and two on the other. I just need to know which way round they go. Surely someone here has done it. I still haven't had a single reply on STD. At least people are replying here. Thank you all
Get a magnifying glass and look at the chips and gimme the chip numbers. if u can show a picture of them on here aswell. I can tell u which way they will go. number on them will be something like....... 95P04 maybe..............
Much appreciated mate. I'll send it to you later. Thanks
