What the optimum mph should I drive to get the optimum mpg in my 1997 W202 and 2001 W170? Is it 55mph or 65mph? There are no trip computers in either.
Nothing will improve the mpg more than good driving. Good forward observation, good anticipation and of course always being in the right gear for the right speed.
I would suggest that every car will be different but never be in too high a gear, but don't be afraid to use the highest gear that is suitable for the conditions.
For a competent driver I would suggest that forward observation, coupled with anticipation will make the biggest saving.
John
Driving an automatic will indeed probably eliminate the need to change gear but what would be the sense in accelerating to a given speed when within yards there will be a need to slow down? All a driver will do is waste fuel and my point is that to give a mandatory correct speed will never be as black and white as we might like. In an automatic it would be crtazy to go down a very long hill on a motorway and periodically brake to keep to this so called optimum speed, again my point is all about forward observation. The driver can lift their foot off the throttle and let the car dfo its own thing. I have gone down Telegraph Hill which is a dual carriageway at 70mph (ish) and the computer was registering 99.9mpg. Should I have braked to rteduce speed?As most cars are automatic it will always be in the right gear for the best part, this is where the 55 mph drops into the equation, the car will be in top
What is this thread about, driving like an idiot of getting the most out of your car on a reasonable journey.I just feel that mandatory speed limits are wrong when answering such a complex question.
John
On the point of using the brakes, I never use mine if I can avoid it as it makes the wheels dirty
So that would mean around 60 in topWith superchargers (kompressors) being common on MBs, driving off boost will also boost economy. By that I mean keeping revs below the point at which the clutch engages the kompressor, which for a C32 means keeping below 2700rpm, or ideally less than 2500rpm.
Nobody ever drive at 55mph unless it a very old vans or vehicles without MOT.
