Parktronic W203 C180K
rossmcd
C180k w203
Hello from New Zealand
I have a 2004 W203 C180K, this model has no parktronic. The bumber inserts look to be as per the Avantgarde model. Has anybody added parktronic to this model, is the wiring there? I presume that i will have to add the inserts, plug in and add the displays?
Look forward to the guidance from a master.
Cheers
Ross
would cost an awful lot to do the bumpers should have the cutouts in the backs of them you only need to change the bumper inserts, plus the the front and rear
wiring looms for the bumpers then connect from under the bonnet and in the boot area the plugs for them should be already fit to existing loom on the car but the sensors are expensive hear in the uk they are £55 + vat each, so the best bet if you
can source these from a donor car
Gud luck
