What graphics card do you have and what PSU do you have if you are using your old PSU for this board it may be the problem as LGA775 motherboards require more power and likewise do PCI-E graphics cards
I'd be suspicious of a Q-TEC PSU ...
Really? they meant to be poor? its served me well for the past 3 years
Trouble is, I dont want to spend another £50 and find out it wasnt the PSU afterall
I still havent contacted or left feedback to the seller ether.
One thing that I have also noticed, I dont get a light on the keyboard at all, and pressing F1 for example jouring start up does nothing. Why wouldnt I get any power to the keyboard then?
On most desktops the PS2 keyboard connectors don't power up until the BIOS recognises them (that's usually the point where you get "Hit F2 for Setup" etc on the screen). Unlike the USBs which draw power once connected.
Do you have access to any other desktop PC you could "borrow" the PSU from?
The board we're talking about is quite thirsty for juice and needs both 24 and 4 pin power connections to the board plus the usual drive & graphics card connections. The 20-24 adapter should usually work - do you have the 4 pin supplementary power plug on your existing PSU?
Sorry for the slow reply,
Just had another go at it,started it up with nothing attached at all (including RAM!) The speaker started to beep! At least we know that works after all!
With 1 stick off RAM attached, the beeping stops, still nothing at all on the monitor
My PSU is a Q-TEC PSU 400WP Dual Fan gold - attached with a £3 20-24 pin adaptor
Thanks in advance.
I would definitely remove the CPU and re-seat it again. Have you got the heatsink and fan on firmly with just a smidgin of thermal paste on there too?
Did you maanage the CMOS reset mentioned on page 2 of the thread?
