S63 AMG Coupe, Range Rover Sport, 992 Porsche Carrera 4S
Can't fool me, these wheels are different Nice, but I prefer the previous ones
Just away to give the Range Rover a 30 minute wash. Back in 90 mins I guess
Yep, put the original wheels back on, to see if I could cure a vibration through the steering wheel, and it did, so it's either the tyres or the alloys that's causing the vibration.
So much for 90mins, only 3 hours. God knows what I get up to. Snowfoamed under the arches, off road height is great for this. Wheels cleaned then pre rinse (I know that some don't but I do), snowfoam, dwell, spray off. Different snow foam, why different ????? then clean with noodle mitt. Spray off till clean. I have a long 90 degree wand which gives great pressure for cleaning the roof & underside. Only £9.99 from Lidl a while back. Saves time getting the steps out for the roof. Leave car wet then use Meguirs last touch detail, spray on wipe over with micro fibre then buff up with another micro fibre. Only takes about five mins longer than just drying. Another time saver. RainX on front screen then quick 5 min run to clean rusting brake discs. Sometimes spray discs with AtomMac before starting which prevents rusting, but often forget. Where did my 3 hrs go?????, but I enjoy it that's the main thing
Possibly wheel balance if its through the steering wheel. You may have lost a balance weight.
I have Gtechniq C4 on all the under bonnet plastics & am pleased with it. However when re-applying my Autoglym tyre gel, I thought about the under bonnet plastics. Tried a little mmm, pretty good & as you do, half an hour later it was on all under bonnet plastics including rubber hoses, actually anything that looked black. Let it dry & I am delighted with it, lovely finish. Far cheaper than C4, See how long it lasts
Hope it dosn't melt the plastics & hoses
