Al, thanks, fresh air flaps OK, with the fan removed I can see daylight when the flaps are open.
Nomoneybutamerc. Thanks,. new vacuum valve on the heater control valve so can test when I re-assemble as the switches are now within reach.
I have dived in at the deep end. Drivers seat out, handbrake removed, radio out, gear change cover, tunnel cover and walnut trim around gears and flap levers out.
Currently staring at a jumble of wires and can see that the flaps aren't moving so trying to decide whether to go deeper and remove the whole ventilation flaps and heater box.
One thing noticed is that 2 plastic covers (100mm x 100mm) at the bottom of the ventilation box have dropped off. Assume they must be blanks for the floor vent trunking on the more upmarket versions.
Suspect that this is where the excess heat was coming from, but they wont clip back into place.
