Thought I'd share....
So, last year I started having the usual issues with the fuel pump relay - basically, when you turn the key, you don't hear the whoosh of the fuel pump, and the engine turns but obviously it doesn't start as the fuel pump isn't on.
I took the relay out, re-soldered it (although there was nothing obviously dry in there), put it back in and hey presto, fixed.....
Until I went to start the car earlier on in the week, same issue so I took it out, cleaned the pins, accidently dropped it on the ground, refitted it and again, fixed....
But this spurred me on to find a replacement....
Now as anyone who has looked for an original, they are horrendously expensive from MB. The cheapest second hand "good" one was around £50 (someone asking £160 too!). So I thought I'd have a punt on one of the OEM ones from e-bay.
So I did a little research and noted that a load of sellers have part number A0035452505 as a direct replacement for the original (A0025451605). The part looks like a URO part (I've used their seals before and they are a good fit), and for £22.80 with a 2 year warranty, worth a punt.
So tonight I went to fit it and noticed that the unit is pretty much the same but the new unit has an extra pin- basically the old unit has a row of 8 pins and another row of 3. The new unit has a row of 8 and then a row of 4.
Thinking what the hell, I fitted it anyway.... and it works. The car started fine. I revved it and it revved, and most notably, I've been suffering a slightly high idle (around 900-1000 rpm) which I was pretty certain was down to vacuum, but with the new unit, the idle settled down to more like 700-800.
So I guess the only questions I have is, what is the extra pin for and will I see any issues in using this relay? Be interested in peoples input!
