R129 Alloy Wheel Offset Question
Vlad
Reading, England
Various Mercs come and go
R129 Alloy Wheel Question
Will a set of 17" alloys with a 25mm offset fit a R129 SL?
MANY THANKS
According to the list stickied at the top of the wheel/tyre forum that's a valid offset assuming the wheels are 8.5" wide for the front axle and 9.5-10" wide on the rear axle.
Hi Vlad
The width is the key, but yes, assuming they are within 8.0 inch to 10 inch width, they will work.
A good reference point is the AMG spec for the SL, the 2-piece 8.5s front and 10s rear....these wheels all had 25mm offset. If the fronts were 8 inch instead of 8.5, that's fine as they would only protrude less given the lesser width and high offset.
talbir
Talbir thanks for that......the wheels in questions are a set of Intra's....ie AMG copies and they are 7.5, so I assume that these will not fit.
They'll fit, but they'll sit deep inside the arches, won't look pretty.
Are they copies of the 2-piece AMGs or the Monoblocks ? I thought the Intra copies of the 2-piece staggered AMGs were the same width as AMGs, i.e. 8.5 + 10 ?
I think the Monoblocks were possibly narrower though.
cheers
talbir
Talbir the ones I had my eye on were 7.5J........in light of this I'm going to give them a miss I think, and hold out for a set of genuine staggered AMG's as and when they turn up at the right price.
Many thanks for your help....much appreciated.
