R129 Creaky hard-tops?
bruiserdennison
Am just about to sign on the dotted line for a 94 500SL but am a little worried that there are a few creaks from the hard top during driving - is this normal?/can it be resolved with a bit of silicone?
Bruiser
They do creak a bit - MB sell a special lubricant for the seals that helps though check the windows are aligned properly - does it creak with them down for example?
I've had 3. They all creaked a small amount. Anything substantial may represent a problem. Get it checked by someone who knows before you buy if possible. Where are you/the car based?
I'm obviously lucky, mine has never creaked.
Me neither, I'm not quite sure what you mean by creak, certainly my hardtop makes no noise whatsoever (except when engaging/disengaging from the lugs when being raised/lowered. When driving with it on you'd be hard put to know it wasn't an ordinary saloon.
stats007 said:
Saloon?!?!?!
Have I badly expressed myself here? What I meant to convey was that driving with the hard top on is no different to driving a car with the top more permanently afixed!!
Silcone grease on the seals seems to help...........
