television
Hardcore MB Enthusiast
I will sort out some more details for you of checking the roof.
The details for the windows dropping are not given
Hi
Is the door handle switch the same as the limit switch? Where is it located please?
I was thinking soon as you pull open handle inside or outside the car window drops but thought limit switch made the window do this?
Hopefully getting closer to solving problem, cant believe changing a battery could cause so many problems![]()
Hi
Hi Popped into Mercs Brentford and they said as my car is 1997 only a limit switch is showing on their system not a door switch? I explained the exact role of the switch and what it does, even took printout of the the post with diagram, but the guy couldn't help me:-( If i remove the lock is there anyway i can test it? Thanks guys for being so patient and helping me out
I don't think the window convenience feature is connected to the lights? Doesn't the pin just send a CAN signal to the dome light? The door would have to be open before the light came on and would render the window dropping useless at that point.
Malcolm's diagram is for a 129064 car - yours is a 129063 according to your earlier post?
You might be right - I know the puddle light is wired to the door pin - so maybe that is seperate?
Certainly puzzling!
You do get the odd glitch if you open the door too quickly - but not really a regular occurrence.
