N10/2 Relay - R129 SL320 - 1996 model
Interesting view of these relays. Alot of electronics contained within.
Further to last email, please disregard the bit about pulling back the tab with a screwdriver. The wiring connector block that receives the pins from the relay is housed within a sliding rail, this rail extends to about 2/3 the length of the relay casing, you simply push the inner end of the sliding rail towards car windscreen direction, this motion has the effect of lifting the wiring pin block up and it unlatches the complete assembly ( wiring connector block + sliding rail ) from the bottom of the relay. DO NOT remove the wiring block connector from the sliding rail mechanism by removing the rear small wrap around locking mechanism that fixes the pins into the connector block. I mistakenly did so and it is a pain to get them back in again. They are housed within a plastic grid so at least the wires did not get mixed up. Patience and inserting a small nail into each pocket until they all line up and pressed into the block and back on with the 3 sided wrap around locking rail and a bit of levering to prise it over the 4 small pins. Warning - no need for this so do not remove it.
My relay is the same as the bottom picture. The larger combination relay,I managed to get the top off but my numerous attemps at releasing the pcb base plate failed. An experienced member from another forum kindly offered to open it and check the solder so hopefully it may be repairable. ( €530 from MB Ireland to replace )
I did buy a replacement from Ebay before the repair offer arrived. I have fitted that but the very same issue arises. Fast wipers work fine. Slow and intermittant do not although they tried very slowly and moved a few inches and stopped. I can hear something click when I turn on wipers to first setting but still no movement in slow / intermittant. Could it be that the relay I purchased has the same issue. The seller sold it on the basis that it was working.
So now there is a few possibilities, maybe the relay is still the issue. Is there any way of testing the combination with a multimeter?. Could it be something else?. as the fast wiper works 100% I assume there is no issue with the wiper mechanism itself.
A bit disappointing thast the replacement did not work but hopefully I will get some good news from the generous repair offer. I would love to know if these is a test to evaluate these relays. There was one posted for the OVP on a W124 which helped my to get my E220 CE started.
