Recently my 2003 SL started 'clicking' heavily from both front roof latches on bumpy roads. I did a bit of digging and subsequently replaced the intermediate pivot pins then tightened everything up a little and the clicking has mostly gone.
As a result of this tightening up I do now have another problem. The roof needs to close about another 0.2mm or so to sit snuggly against the front seals. There are two long black pins on the front latches which seem to trip microswitches in top of the windscreen crossmember. There is also a microswitch in the offside roof latch.
Can anyone advise if there is any adjustment in either the roof latch or where it locates on the window frame? I have access to WIS and cannot find any docs relating to this.
Thanks in advance, Robert.
