jareddavis
- Oct 30, 2012
- mercedes sl 350, r230
If anyone can help, my 2004 Sl350 keeps blowing the PSE fuse and I am somewhat confused.
Previously had the pump replaced and protected new one in bubblewrap. This allowed water to get in and soak the sponge (clearly thought I had done a good job) but having checked the pump, its all in order. Took it out of the casing and all clean and fine. The plugs are slightly tarnished but I think that is from the previous time the pump actually blew. Having dried the boot out completely and the sponging, thought I had finally solved it. Ran the central locking on and off and all fine. Then I went on holiday, left the car unlocked and the moment I drive off in it and lock it, the fuse blows.
The fuse has now blown half a dozen times and each time I think its solved, the fuse blows again. I cannot work out what is happening so wondered if anyone knows what other electrical items run on the same path as the PSE? or is the symptons point to anything else?
Regards
Jared
Regards
Jared
