I was glancing throught the manual/documentation that the dealer provided for my car (W203 saloon) but have so far been unable to locate the "security/pin code" for the radio (if the battery was to go flat or disconncted then I would need to reneter the stereo/radio code in order to reactivate the unit.
Please can someoe advise where abouts in the doucmentation I shoud specifically refer to for the security/pin code i.e. data card in the service book (unless the documentaion has not been accompanied with the security/pin code). If this is the case then I`ll have to refer to the dealer to obtain the info as the unit was factory fitted and should therefore be available from data records from the vehilces vin number.
Flash
Flash
