My drivers side rear tail light has packed up on the W124 1992 coupe. It's not getting any power. The rest of the light works fine. The plug that goes into the bottom of the bulb mounting board isn't getting any + power the earth is fine. I've read in the Haynes manual that there is a lighting control unit between the light sector switch in the dash board and the rear light cluster. Where is this to be found? Is it the box I've found under the left rear passenger seat?
The light buzzer still works which takes power from the driver rear light fuse so there power getting as far as the fuse box. So that says to me that the dash switch is working fine.
Any help would be great.
