Yes but it's only clear that we need that part based on visual inspection, which could have been retrofitted. I am going to try and get MB to send a pic of the pump they have on hand.
I mean, how often is MB EPC wrong? I genuinely don't know.
VIN: WDB2304712F120719
Hey Connor (& anyone else who reads this & might shed some light on this?); I've run into a similar issue as you. I would have PM’d but I don't think I can PM because I'm new here. I’m interested in what you did with yours in the end?
I was supplied with the wrong part after various assurances from the supplier here in the UK pre-purchase - that it was definitely correct.
My local Mercedes dealer couldn't get their part for a few weeks (& no gty on that either). As I may not have been able to return the incorrect part & that it is not too dissimilar from the original; I thought I’d see if this would actually do the job - especially given other comments in this thread - basically saying it’s just a 12v pump.
It’s a Bosh part, a little bigger than the original, so it may consume more current than the smaller original.
The main difference is that on the original - the input to the impeller chamber has two hoses (3 in total; 2 hoses in & 1 out). The smaller hose input (12mm ) is absent on the new pump.
As 12mm is going into the impeller chamber, I figured that I just need to use a t-piece reducer before the input - job done. So I've done just that and it’s all fitted and at temperature, no leaks (given there are more joints now - this was important).
Ok but now, the new pump is fitted - it’s not starting up; it actually pulses for a split second, once ever 10 seconds, for 3 times (& doesn’t try again until engine restart or the parking heat (“rest”) function is enabled on the dash.
This might just be that I need to clear off the original fault (which basically said there was a short on the heating circulation pump / circuit).
The electrical connector on the original pump was heavily corroded and actually came off in my hand (on the pump - not the loom / car-side connector) so there was certainly a short there - so that fault made perfect sense.
I do not currently have a diagnostic right now; I ordered a Mercedes SDS C3 on Monday but it’s still being built I’m told.
So, after I’ve cleared the fault - it *might* be good but I am doubtful given it is trying to start now.
I wonder if the ECU is thinking the new pump is drawing too much current - as I said, it’s a bit bigger than the original one. If so, perhaps I need to put a resistor in series with +ve to reduce the current that the new pump can draw - I guess this might mean the pump runs slower but as its bigger, I don’t see that as a big issue.
I would need to know what size resistor to go for, if anyone thinks I’m barking up the right tree. 0.5ohm if 12-14.5v - unsure what watt to use?
Thoughts ? Thanks so much in advance (VIN is above).
BTW, anyone near Chester area that needs access to an SDS, I’m more than happy to help you (free obv.) - when it arrives!
