Received invalid "OEM matched" part for aux water pump - R230
Thanks O.P. 😁 I’m literally starting it now - so your timing couldn’t have been any better!
Already noticed that someone else has had not replaced red door poppers - so will need a few of those - I should have anticipated that 😳😁
Yes, noted one had been misaligned last time card was off & had been crushed. I reconstructed it & then forgot to re-set it back in it cradle before re-fitting the door card 😡 Noticed on drivers seat under a cloth (fume) hey ho! :)
Dealer says they have to take the car in to get that new key (they said "would just work" diagnosed - bet they somehow make it the car's fault & charge me diagnostic's! 😒
I am so glad my old W124 is none electronic . Mercedes have you over a barrel .Most new parts will need programing .Still your getting there bit at a time .
Agreed on that and adding to that point; with having the car on the diagnostic, I noticed the car's PSE (air pump in the boot) was bleating about a timeout on the boot closure mech. Now, when I was originally viewing the car, checking inside the boot, I'd gently closed the boot leaving it a little ajar & as nothing happed (I expected soft-close), the seller before the thought had formed in my mind; "It's not got soft-close!". I remember thinking "that was odd" but I thought nothing more (though, I noticed the panel gap on the boot was wider toward the bumper that it was toward the roof - which I asked him about & he just said he'd never noticed...I ended up moving the hasp a little later to line it up properly).
So, now with that DTC int he diagnostic, I thought, did he lie to me? So I called the dealer to check if my chassis had the part fitted & get a quote and well, I think they probably all do - but mine certainly has. The seller did bullish*tt me then which explains the panel gap - which I'll have to restore. Not surprised as there was a few more lies in the listing - which didn't bother me too much but it said it had Distrionic, the seat upgrade blah blah - again, bullish*t.
These are prone to air leaks & can be repaired more often than not but a new actuator is circa £300 (fume)... So again, agreed your original comment! I;d like to order a new part as fixing them, whilst easy, is messy as it's typically done with epoxy & then the repairs may not last - but I've spent soooo much money bringing this car back, I want a break from the money I've poured into it.
On a positive note; I'd been struggling to get the set the time (clock) that's on top of the dash - with a new option enabled on the car's MFD / dash
the former owner had removed "Comand", replacing it with a Pioneer CarPlay unit - so the setting the time on the dash option was no longer possible - except for pulling the battery & restoring it @ 12:00noon - quite annoying (to me anyway..).
Reading a forum post somewhere, somebody said that it's possible with Star in Developer mode. On that note; I asked a specialist with SDS to do it for me, providing him with instructions from the poster & well, he couldn't do it even with the instructions (& somehow my reverse park passenger moirror drop function stopped wrong after that. which I thought was the battery but it was actually his SDS session). I then tried the Merc dealer - who basically sent me on my way.
So after trying a few other leads which turned out to be dead-ends and that I'd been unable to secure my own SDS from a diagnostics equipment seller (2 weeks of excuses after I'd paid for it so I just asked for a refund) I researched a generic, but 1/2 decent diagnostic (as my daily is an A8) and wouldn't you know it, I was able to do it with that (plus some other stuff) really easily. I was really pleased - taking the battery off annoys me for all sorts of reasons.
So If anyone needs to have the set their clock function on the MFD when they no longer have Command in the Cheshire area, I'll happily do it for you for free!
I took too long editing my typo's & so couldn't post - this was the edited version!!
Agreed on that and adding to that point; with having the car on the diagnostic, I noticed the car's PSE (air pump in the boot) was bleating about a timeout on the boot closure mech. When I was originally viewing the car, the seller said "It's not got soft-close!". I remember thinking "that was odd?" but I thought nothing more.
A minute later, I noticed that the panel gap on the boot was wider toward the bumper that it was toward the roof, I asked him about that & he just said he'd never noticed...I ended up moving the hasp a little later to line it all up properly - but I shook have clicked then but I didn't.
So now, with that DTC in the diagnostic, I wondered if he'd lied. I called the main dealer to check & get a quote. Whilst I suspect they all have it, turned out mine definitely has it. So the seller bullish*ted me, explains the panel gap issue (I'll have to reverse that when I fix the boot actuator. There was a few more lies in the listing text (in Autotrader) which didn't stop me buying the car but now, I should have added it all up!
230 boot actuators are prone to air leaks & can be repaired, a new actuator is circa £300 (fume)... So again, agreed your original comment re. electricals. I'd like to just order a new part as fixing them, whilst technically easy, is messy (typically done with epoxy & then the repairs may not last) but I've spent soooo much money bringing this car back, I want a break from the money I've poured into it. It's at the wheel reformers now & when it's back, I still have a new rear calliper to fit on as that's another little easter egg the previous owner broke (piston was broken when he "refurbished" the brakes - but after breaking the ceramic ring on the piston, he just reassembled the broken piston, and then the pads - which was causing a lot of squeaking (& could have been very dangerous)... I'd bought new pads prematurely so I caudal fix the squeaking for myself once & for all & on starting with the rears (being easier than the fronts) that's when I noticed broken piston (I really struggled to compress it - unlike the other side which retracted easily).
On a positive note; I'd been struggling to get the set the time (clock) that's on top of the dashboard (basically by enabling an option, on the car's MFD / dash) because the former owner had removed "Command" & not given it me with the car (fume), replacing it with a Pioneer CarPlay unit. So setting the time on the dash-clock was no longer possible - except for pulling the battery power & restoring it @ 12:00noon - quite annoying (to me anyway..).
Reading a forum post somewhere, somebody said that it's possible with Star in "Developer mode". So on that note; I asked a specialist with SDS to do it for me, providing him with instructions from the poster & well, he couldn't do it even with the instructions (& somehow my reverse gear passenger mirror-drop function stopped working after that which I initially thought was actually the battery being pulled & replaced - for my setting the time & yes, I'd gone through the store function - def. stopped working - it was actually his SDS session that did it). Anyway, I then asked if I could pay the Merc dealer to do it - but they sent me packing.
So after trying a few other leads which turned out to be dead-ends and that I'd been unable to secure my own SDS from a diagnostics equipment seller (2 weeks of excuses after I'd paid for it so I just asked for a refund), I researched a non-Merc specific / generic all brands (but still half-decent) diagnostic for general stuff (my daily is an much more modern Audi) and wouldn't you know it, I was able to do it with that (plus some other changes too & fix the reverse mirror thing too) really easily. I was really pleased - taking the battery off annoys me for all sorts of reasons plus it's a little risky with the BCM in the R230.
So If anyone reads this & needs to have the set their clock function on their MFD when they no longer have Command & are in the Cheshire area, I'll happily do it for you (for free!). It's only a small thing but god, so annoying. I'm also going to turn off the "Nav" function on the MFD as it serves no purpose & removes a button push when traversing the car's menu's. May do the same for "Phone" as well plus pull the fuse for the module (these can sometimes hang & cause parasitic battery drain).
The CD changer behind passenger plus the comand-nav DVD rom/player/drive is still in the boot whirring away are both redundant too - so I may research how to de-power those, preserving originality of course (so leave them there & wiring left dis-abused).
Also!! Noticed the drivers wing mirror (which tints when a car with lights is behind at night) *may* be leaking - noticed a funny looking mark through the glass at the bottom. So I gt a quote - just for that glass £325!! CHOKE! Last one too (ever - they're not maufacturing it any more) so I think I'd like to get a used one for that - albeit, it's not gone yet.
